Sending data from a cube view to Access
cw1194
Post by cw1194 »
I could really use some help if someone has an idea. I need to get a value to access from my cube view and am getting an SQL error.
In my prolog tab I have the following:
Source='sendodbc';
ODBCOpen('sendodbc',' ',' ');
(sendodbc is the name of the odbc I set up to connect to my table called sendodbc in access)
ODBCOutPut( 'sendodbc', expand('INSERT INTO sendodbc [Store] VALUES ( Store)' ));
(again sendodbc is both the name of my driver and the access table I am trying to push information to)
(there are actually 6 fields in the view but I set the other fields to ignore in the variables tab)
ODBCClose('sendodbc');
this is a rehashing of a post I put out about 7 weeks ago...I was never able to get it to function properly.
Re: Sending data from a cube view to Access
Post by David Usherwood »
Do an asciioutput to file of the exact string you are sending to Access via ODBC and see if it is valid SQL. Expand is not a nice command and TI doesn't have debugging tools. The SQL is probably invalid - quotes etc.
cw1194
Post by cw1194 »
When I input the following asciioutput statement:
asciioutput('c:\temp1.txt', ('INSERT INTO sendodbc (Store) VALUES ( Store)' ));
it returned the following into my temp1.txt file:
"INSERT INTO sendodbc (Store) VALUES ( Store)"
I am assuming I want to see actual values and not literals correct? Do you know why this is happening?
cw1194
Post by cw1194 »
Okay I changed the ASCIIOUTPUT command to:
asciioutput('c:\temp1.txt', store);
and it actually returned the first value in my cube view. So I guess I just need to sort out my SQL statement....which has proven a difficult task.
Not sure if this is the approved way to post a link to another post, but you should look at
http://forums.olapforums.com/viewtopic. ... tput#p2228
It even talks about Access - you're in luck! (Except that I would say you would be more in luck if you could use SQL Server :) )
David Usherwood wrote:Not sure if this is the approved way to post a link to another post, but you should look at
Around these parts, the "approved way" is usually "whatever works". :D
David Usherwood wrote: It even talks about Access - you're in luck! (Except that I would say you would be more in luck if you could use SQL Server :) )
Hmmmm.... I thought that there was something oddly familiar about this thread....
