Hello everybody,
I'm facing a technical problem with COGNOS TM1, i have a dimension that includes an element with apostrophe (i'm using TM1 in french), the problem is when i want to use this element in a rule TM1 doesn't recognise it because the elements are used in the rules with quotes, and TM1 confuses the quote with the apostrophe. here is my rule: ['Chiffre d'affaires (HT)']=['Quantité vendue']*['Prix unitaire'];
I hope i was clear, plz cloud anyone help me any suggestions are welcome.
excuse the spelling mistakes
apostrophe problem in TM1
- Mike Cowie
- Version: Anything thru 11.x
Re: apostrophe problem in TM1
Hello:
Try escaping the 1 single quote in the element name with 2 single quotes:
This is TM1's escape sequence (2 single quotes together = 1 single quote in a name) so that you can refer to a single quote in the element name and avoid this problem (also works in Turbo Integrator, too).
Hope that helps!
Mike
['Chiffre d''affaires (HT)']=['Quantité vendue']*['Prix unitaire'];
Hope that helps!
Mike
Mike Cowie
QueBIT Consulting, LLC
- OLAP Product: OLAP
- Version: TM1 9.4
- Excel Version: Microsoft 2007
thanks a looot for the tip it worked
