Modifying an existing process to load a new attribute
Dirion
Version: 9.4
Post by Dirion »
Relatively new to TM1 but not to databases of code generally
I have added 2 new attribute collumns to the csv file I use to update a dimension and modified the TI process to assign variable names to them , listed them ans attributes and added them to the attribute map yet when I run the process the attribute exists in the dimension but the data has not been entered.
the generated code has a correct looking CreateAttr and AttrPuts line for each of them.
Anyone any idea what I am missing
Re: Modifying an existing process to load a new attribute
If you post a screenshot of your data file, the variables tab and your code on the data tab then I'm sure the answer will be obvious.
