I configured TM1 9.5.1 with LDAP Novell NDS without SSL Security!
users have been correctly imported in TM1 via ETLDAP Tool , i set one user as administrator and PassWordSource to LDAP
But when i try to connect the user with LDAP Credentials, i get the error: "Connection failed: LDAPServerConenctionFailed"
Could you explain me what to do?
Thank
LDAP Configuration with TM1 9.5.1
- Version: 9.5.1
- Excel Version: 2003 2007
Re: LDAP Configuration with TM1 9.5.1
Stephane wrote:I configured TM1 9.5.1 with LDAP Novell NDS without SSL Security!
The ETLDAP tool is not TM1: The ETLDAP tool supports both the unsecured LDAP protocol and the secured LDAPS protocol, but TM1 supports only the secured LDAPS protocol.
Thus LDAP user authentication in TM1 9.5.1 will not work when using a Novell NDS without SSL Security.
For more information on TM1 and LDAP user authentication see the Cognos Proven Practice "Configuring LDAP authentication for TM1 9.5":
http://www.ibm.com/developerworks/data/ ... ge498.html
IBM Cognos Proven Practices: Configuring LDAP authentication for TM1 9.5
Summary: This document is meant to supplement the TM1 9.5 Operations Guide as it describes the task of configuring LDAP authentication for TM1 9.5 in greater detail.
http://public.dhe.ibm.com/software/dw/d ... M1_9.5.pdf
- Version: 10.2.1
Hi Stephane,
Have you configured LDAP using SSL security. If yes, have you used LDAP server CA certificate for configuration? Please let me know.
Also how to get the Certificate from LDAP server.
Manoj
Manoj
