TI to TM1 workflow
sreecharan
Version: 9.5.1
TI to TM1 workflow
Post by sreecharan »
HI,
I want a suggestion can we attach TI process to TM1 workflow.
If so please give me steps.
Thanks and reagrds
TM1 9.5
xp
excel 2007.
sreecharan
Version: 9.5.1
Re: TI to TM1 workflow
i got the information like we can connect TI to TM1 workflow, but for like how TM1 workflow connects for assigning the task and approval of tasks like.But i what i need is, can we connect TI process of updating the data to cube, updating dimension what we do generally like loading and maintaing the data using TI process, such can be connected to TM1 workflow.
Thanks and regards.
It depends what yopu mean by "TM1 workflow". If you are talking about contributor then no at this point in time (up to 9.5.2) this simply isn't possible as the only objects available to contributor are cube views.
However if you are talking about old school TM1 workflow then the answer is yes of course you can. You just embed an action button that calls the TI process in an application folder worksheet and attach the worksheet in question as a workflow task object.
sreecharan
Version: 9.5.1
thank you,
yea i was asking about the TM1 workflow not contributor
