Dimension utilisation - finding redundant dimensions
- Martin Ryan
The attached TI process will cycle through the list of dimensions and find out which cubes they are used in. If a dimension is not used then it puts out "-" in the cube column. This can help you identify which dimensions are no longer being used.
- Info_DimensionUtilisation.pro
- (2.56 KiB) Downloaded 3873 times
- jim wood
- Version: PA 2.0.7
Re: Dimension utilisation - finding redundant dimensions
Very handy indeed.
Kyro
- OLAP Product: MODLR - The CPM Cloud
- Version: Always the latest.
- Excel Version: 365
Brilliant! thanks for this.
LoganNSE
- Version: 9.5.2
- Excel Version: 2003 2007
Excellent!! Thanks for the code.
Logan
Logan
tosca1978
- Version: 9.5.2
Hi Martyn,
I can't seem to open the attachment once it is downloaded? It asks me to search the net for an appropriate program to open the file. Can you tell me how to open using TM1?
I'll save "Martyn" (sic) some typing.tosca1978 wrote:Hi Martyn,
It's a TI Process (.pro) file. You don't open it (though you can using Notepad if you want to see what's in it first), you put it into your data directory so that the server can register the process the next time it restarts.
tosca1978
- Version: 9.5.2
Martin - apologies for the typo and many thanks for the TI - it's exactly what I wanted.
Alan - many thanks for pointing out what I needed to do - much appreciated.
tosca1978
- Version: 9.5.2
Hi Martin - sorry another question!
Is there anyway of establishing if a dimension (and cube for that matter) is referenced in any rules or TI's? I have a few dimensions in my model which are not used in any cubes but are referenced in some rules. As I inherited this model from another developer (with no technical documentation) I am pretty nervous about deleting dimensions and cubes although the model definitely needs tidying up!
- Martin Ryan
There are some clever documentation tools out there somewhere but you could also use the TM1 tools add-in which probably give you want you need more quickly. The specific tool you're after is described...
As well as searching for cube references using this functionality you can search for dimension names. Or any text at all.- The ability to load text files (including .pro and .rux files) into an excel workbook and then search them for a specified text expression. This can help determine the TI processes or rules which affect a specified cube.
Alternatively, you could use tools like Notepad++ to search in several files and folders. Also, regex and other features.tosca1978 wrote:Hi Martin - sorry another question!
rogovem
- OLAP Product: TM1, BI
Hi Martin,
is it possible to make finding the cubes for two dimensions?
Egor.
Egor.
- Martin Ryan
Hi Egor,
I'm not entirely sure I follow your question but if you're asking whether you can check on just two specific dimensions then there are two approaches. The easiest one is to look at the extract file and just hide/delete all the dimensions you're not interested in.
The other option is to add a line like the one below, which will skip any dimension except 'Dimension1' and 'Dimension2';
if(sDim@='Dimension1' % sDim@='DImension2', 0, itemskip);
If that's not what you're asking could you try rephrasing your question?
rogovem
Hi Martin!
sorry for the wrong question.
I had in mind is to figure out a full set of cubes that uses two particular dimensions at the same time.
Perhaps these examples will help to explain what I mean:
asciioutput(exportFile, sDim1, sDim2, sCubeName);
Egor.
Egor.
- Martin Ryan
Ok, I see what you're trying to achieve. This particular process wouldn't do it. Here's how I'd probably do that
- Create a new process
- Use the All subset of the }Cubes dimension as the TI source
- Set the variable to be called sCubeName;
- In the Prolog tab have something like
- in the Data tab have something like
Hopefully that'll point you in the right direction. You can do whatever tweaks you need within that if statement.
keyDim1='MyDim1';
keyDim2='MyDim2';
sFile='C:\myfile.csv';Code: Select all
nKeyDimCount=0;
# cycle through the dimensions in the current cube
j=0;
while(j<40);
j=j+1;
tDim=tabDim(sCubeName, j);
if(tDim@=keyDim1 % tDim@=keyDim2);
nKeyDimCount=nKeyDimCount+1;
endif;
end;
if(nKeyDimCount=2);
asciioutput(sFile, sCubeName, 'Has both key dimensions');
endif;Martin
rogovem
Hi Matin!
This is exactly what I had in mind.
it works great!
I think that I could not do it myself.
You have helped me incredibly.
Thank you a lot!
Egor.
it works great!
Thank you a lot!
Egor.
ldwnt
- Version: 10.1.1
Thanks for the process example. But I notice that a variable 'j' is used to go through all dimensions in a cube & it's assumed to be less than 20. I wonder if there's any way to find out the exact number of dimensions associated with a cube in TI?Martin Ryan wrote:The attached TI process will cycle through the list of dimensions and find out which cubes they are used in. If a dimension is not used then it puts out "-" in the cube column. This can help you identify which dimensions are no longer being used.
You just make the while condition check for the result of the tabdim function (returns a blank string if the dimension index argument is a number greater than dimensions in the cube).ldwnt wrote:I wonder if there's any way to find out the exact number of dimensions associated with a cube in TI?
i=1;
While( TabDim(sCubeName, i) @<> '' );
sDimName = TabDim(sCubeName, i);
i = i + 1;
End;-
ldwnt
- Version: 10.1.1
It works. Thank you. It would be more convenient if TI provided a single function~lotsaram wrote:You just make the while condition check for the result of the tabdim function (returns a blank string if the dimension index argument is a number greater than dimensions in the cube).ldwnt wrote:I wonder if there's any way to find out the exact number of dimensions associated with a cube in TI?.. at the end of the loop number of dimensions in the cube = i - 1Code: Select all
i=1; While( TabDim(sCubeName, i) @<> '' ); sDimName = TabDim(sCubeName, i); i = i + 1; End;
rmackenzie
Sometimes it is useful to know the number of dimensions in the largest cube in the server (by dimension size). This snippet extends on Lotsa's code to give that answer. I also amended it to only make the call to TABDIM once, and use a continue flag instead, as IMHO this is slightly more efficient:
# minimum 2 dimensions in a cube
nMaxNumberOfDimensions = 2;
# iterate cubes
nCubeCounter = 1;
nMaxCubes = DIMSIZ ( '}Cubes' );
WHILE ( nCubeCounter <= nMaxCubes );
sCubeName = DIMNM ( '}Cubes', nCubeCounter );
# iterate cube dimensions
nDimCounter = 1;
nContinue = 1;
WHILE ( nContinue = 1 );
sDimName = TABDIM ( sCubeName, nDimCounter );
IF ( sDimName @= '' );
nContinue = 0;
ELSE;
nDimCounter = nDimCounter + 1;
ENDIF;
END;
# subtract 1 from nDimCounter
nDimCounter = nDimCounter - 1;
# update max dims if less than dimcounter
IF ( nMaxNumberOfDimensions < nDimCounter );
nMaxNumberOfDimensions = nDimCounter;
ENDIF;
# do next cube
nCubeCounter = nCubeCounter + 1;
END;
# pass to log
ItemReject ( 'Largest cube has ' | NumberToString ( nMaxNumberOfDimensions ) | ' dimensions' );Robin Mackenzie
Jorge Rachid
- Version: 10.2
- Excel Version: 2013
I am trying to use this process but I am facing an error on .cma file.
What I have to do in this case about the exportfile folder on prolog?
Tks,
JR
Tks,
JR
