Deleting Cubes
suhamore
Version: 9.1 SP4+ 9.4.1 FP3+ 9.5.2 FP1
Excel Version: 2003 + 2010
Deleting Cubes
Post by suhamore »
I am weighing below options for deleting couple of dense cubes in our model (size around 10GB)
1. Delete .cub files from data directory and recycle the service
2. From front end, Tm1 perspective, delete the cubes using 'Delete Cube' option
1st one sounds a better option to me. But, wanted to get opinion from experienced users.
Suhamore
rkaif
OLAP Product: IBM Cognos TM1
Version: 9.1 or later
Excel Version: 2003 or later
Re: Deleting Cubes
Post by rkaif »
I would go with the second option and Delete the cube within the Server Explorer. By doing this it will also delete the other files from the data directory which are related to the cube.
CAUTION: To be on safer side, make sure to take a backup before you delete any cube. This will help in case you want something back from the deleted cube :)
Cheers!
Rizwan Kaif
Version: PA 2.0.7
Re: Deleting Cubes
Post by jim wood »
I would go with option 1 if the cube is any kind of size or you have added / deleted views. I have seen far to many server crashes in my time when trying to delete in server explorer. In fact I had that exact problem just the other day, so I can report that trying to delete a cube from within server explorer can cause 9.5.2 to crash as well,
Jim.
Michel Zijlema
OLAP Product: TM1, PALO
Version: both 2.5 and higher
Excel Version: 2003-2007-2010
Re: Deleting Cubes
Post by Michel Zijlema »
suhamore wrote: I am weighing below options for deleting couple of dense cubes in our model (size around 10GB)
I think option 2 is the preferred one - as this will also automatically delete all objects related to the cube, like rules sheet and public/private views... but having said this, I have the same experience as Jim with system instability when deleting very big cubes and even if deleting the cube goes smoothly, the system could be locked for some time while performing the operation - a system stop, delete .cub file and related rule/view files could be the quicker option.
Michel
blackhawk
Re: Deleting Cubes
Post by blackhawk »
jim wood wrote:I would go with option 1 if the cube is any kind of size or you have added / deleted views. I have seen far to many server crashes in my time when trying to delete in server explorer. In fact I had that exact problem just the other day, so I can report that trying to delete a cube from within server explorer can cause 9.5.2 to crash as well
Jim,
I have not experienced crashes when deleting cubes, but am curious about what situations you have. Were there rules from other cubes referencing the deleted cube when the delete was performed?
Version: PA 2.0.7
Re: Deleting Cubes
Post by jim wood »
I didn't have a rules between cubes. I think I have mainly seen it when you have deleted a view then created another with same name. I'm not 100% certain about that so I'll need to look in to it further.
I would say for certain though that deleting large cubes in explorer has defo caused crashes. It might be related to the point above but again I'm not certain,
Jim.
suhamore
Re: Deleting Cubes
Post by suhamore »
jim wood wrote: would say for certain though that deleting large cubes in explorer has defo caused crashes. It might be related to the point above but again I'm not certain,
I agree with Jim. Last evening I tried to delete a large cube, around 8GB, from server explorer and it was kind of taking forever to delete the cube. Also, I could not access any other servers during that time. After couple of hrs I had to kill the thread.
I think I will go with deleting files from data directory option. Of course, I will have to delete all the cube related files manually , but I hope it will be quicker; plus it wont prevent me accessing other instances on the server at the same time.
Suhamore
blackhawk
Re: Deleting Cubes
Post by blackhawk »
Jim & Suhamore,
Very interesting....some of our clients have some very large cubes (80GB+). I will keep that in mind if they ever have to delete them.
Thanks!
