I'm using ASCIIOutput to create a file but need it to be a tab delimited type.
Does anyone know if it's possible to specifiy this in TI?
Thanks for your help,
Fionnuala
ASCIIOutput a tab delimited file
- jim wood
- Version: PA 2.0.7
Re: ASCIIOutput a tab delimited file
It is comma delimited only as far as I am aware. You could write a btach file that opens the file and replaces commas with tabs. You could run the batch within TI after the ASCIIOuput has finished,
Jim.
Jim.
Fionnuala
- Version: 9.4.1 FP3 HF4 and 10.2
- Excel Version: 2007 and 2010
Thanks Jim, I'll try that.
It certainly seems like there's no option in TI so a batch file might do the trick.
Fionnuala
BTW I'm using 9.4FP3
Fionnuala
- Michel Zijlema
- OLAP Product: TM1, PALO
You can use the DatasourceASCIIDelimiter TI variable to specify the field separator.
F.i.: DatasourceASCIIDelimiter=Char(code);
where code is the ascii code for tab.
Michel
Michel
Fionnuala
Thanks very much Michel, that seems to have worked with the code 9 for tab..
I just need to get rid of the "" around each field now,
Fionnuala
Fionnuala
Fionnuala
ok I have it with
DatasourceASCIIDelimiter=Char(9);
DatasourceASCIIQuoteCharacter='';
Fionnuala
Fionnuala
- Michel Zijlema
You can use the DatasourceASCIIQuoteCharacter variable for that:Fionnuala wrote:Thanks very much Michel, that seems to have worked with the code 9 for tab..
Michel
Edit - Ok, you already found that
