Conversion of String Date to Number
Version: PA 2.0.7
Post by jim wood »
Guys,
Am I going daft? does TIMVL only work on time numeric values? How would I go about converting 28-01-2011 (DD-MM-YYYY) in to a numeric value?
Thanks in advance,
Jim.
Mike Cowie
Version: Anything thru 11.x
Re: Conversion of String Date to Number
Post by Mike Cowie »
Hi Jim:
You looking for DAYNO?
http://publib.boulder.ibm.com/infocente ... dayno.html
Slightly different format needed for the date string, but that should get you from a date string to a TM1 numeric date.
Mike
Mike Cowie
QueBIT Consulting, LLC
Version: PA 2.0.7
Post by jim wood »
After posting I found it. Always the way. I'll get my coat and call a cab..........
