Citrix & TM1 oddities
Posted: Thu Apr 14, 2011 5:00 pm
We have two different issues that seem to be related to our citrix setup, but we're trying to track things down. If anyone has any suggestions...
1) One of our remote users was able to login via citrix, open a view, and start drilling down & changing dimensions. But after one or two actions, his connection to TM1 would freeze. other users seemed unaffected by the freeze (though we do have the 20 second timeout set). The citrix profile was deleted and allowed to regenerate and still the lockups persisted. If that same remote user logged in using a different citrix user, he was able to work and navigate the cube normally.
Later we (more local to the server) logged in using the remote user's citrix login, and were able to navigate hte cube normally as well. We're not sure if this was some kind of persisent network issue or something more devious...?
2) We recently enabled roaming profiles on our citrix configuration. When one of our users tries to change a subset in an excel slice, he receives an error that TM1 could not open a file in the \\server\redirect$\user\appdata\roaming\applix\tm1 directory, though I'm not sure which file is the problem -- My guess is subed.tbd, but that file is created fresh whenever I delete it and open a subset from a slice, so I'm not sure if there is a problem writing to the path, or something else.
Any ideas?
James
Edited to Add: TM1 9.0 SP3 Update 7 64-bit on Windows Server 2003
Citrix XenApp for Windows, Advanced Edition
Version 6.0.0
Product Build Number: 6410
Service Pack:0
Any ideas?
James
Version 6.0.0
Service Pack:0
