Edit alias using cube Element attribute
mail_kupi
Version: 9.5.1
Post by mail_kupi »
Hi Everyone,
I try to make alias that is SUBST from own element. i found cube }element attribute save the attribute value and i can use rule to modified.
but i cannot used function in there SUBST([ELEMENT],1,4). any sugestion?
Thanks for your attention
Re: Edit alias using cube Element attribute
Aliases have to be unique. If you are trying to create an alias that consists of just the first four characters of the element name are you certain that there are no duplicates when you limit yourself to just looking at the first four characters of the elements?
Andy Key
Version: 2.5 to PA
Excel Version: Lots
Post by Andy Key »
If you are creating a rule on an }ElementAttribute cube, all rules have to be written as S: (even if the attribute is defined as numeric, which isn't the case here as you are talking about aliases) and so have to use the DB() style reference rather than [ ] even though it is an internal reference.
Or if you are only refering to the dimension element won't
['AttributeName'] = S: SubSt( !DimensionName, 1, 4);
Do what you want?
Andy Key
mattgoff
Version: 10.2.2.6
Excel Version: O365
Post by mattgoff »
mail_kupi wrote:I try to make alias that is SUBST from own element. i found cube }element attribute save the attribute value and i can use rule to modified.
To amplify the part of Andy's post that I think contains the solution: you need to use the !dimname notation.
Matt
mail_kupi
Version: 9.5.1
Post by mail_kupi »
Ok guys.. thanx a lot for the suggestion
i will try it...
really.. really.. thanx..
John Hammond
Version: TM1 Server 11.8.003
Excel Version: 365 and 2016
Post by John Hammond »
Thanks Andy - you saved my bacon with your answer.
As another point of interest even Text attributes are coded as N level elements in the attributes dimension rather than strings...
