drill through question
Posted: Mon Apr 11, 2011 1:26 am
Hi Guys,
Testing connectivitly to a drill through source from an access database. I am trying to drill through to the following. However the TM1 view I have has alias's turned on for the "coo_auext" dimension to show
desriptions. I thought it may be possible to try:
[Profit ctr1] = '?SUBST(?coo_ausext?, 1, 10)?'
to replace line 5 in the following drill TI query:
SELECT *
from [CJ74 Transactions]
WHERE
[RefDocNo1] = '?capex_reference_doc_num?'
AND [Profit ctr1] = '?coo_ausext?'
The only work around I have is to populate an access field with both the "coo_auext" cost centre account with the name tacked on the end ie "0000008210" to "0000008210 - my descripton"
so the drill will work. Can someone kindly provide the proper syntax to make this work, my knowledge is a little lacking in this area.
Shock
SELECT *
WHERE
Shock
