How to find -IF Process Success
vinnusea
Post by vinnusea »
I have Created a ProcessC ,having both Process A and ProcessB.
AIM:
When while condition satisfied Execute Process A, If Executed Successfully then Execute ProcessB ,If ProcessA fails Then quit entire process.
i=1;
While(i<= condition);
ExecuteProcess(ProcessA);
Only on Success;
ExecuteProcess(ProcessB);
end;
I have tried to understand the Globalstringvaribales to do this but couldn't figure what to use and how to use them. Appreciate your time .
Thank you
-Prat
Vinnusea
Re: How to find -IF Process Success
Look in the IBM Cognos TM1 Reference Guide for ProcessReturnCode in the Implicit Global Variables section of TI. That's what you'll need to use.
vinnusea
Post by vinnusea »
ya thanks will try them..
Vinnusea
Or call process B from the end of process of A then you won't need a global var.
Global vars are pretty easy to use
You just put the statement declaring the var global at the beginning of each TI you want to use it in. The var name goes in single quotes, which is a little odd until you realise you are passing an arguement.
ajain86
Version: 9.4.1 9.5 9.5.1
Excel Version: 2003 2007
Post by ajain86 »
The Execute Process function returns a code that can be stored in a variable.
You can then check if the code matches a specific condition and proceed.
Ankur Jain
vinnusea
Post by vinnusea »
Thanks Guys...
Vinnusea
