Hi gays!
Can anybody help me to resolve next task?
I need to open xls-file from TM1Web WorkSheet by MS Excel as external application.
Thanks for your advice.
yng
Run External Application from TM1Web Workbook
- rkaif
- Version: 9.1 or later
Re: Run External Application from TM1Web Workbook
What is the location of the Excel file you want to open? Is it on the TM1 Server?
Have you tried using the ExecuteCommand() function? You can use this function within your TI Process to run a desktop application.
Cheers!
Rizwan Kaif
Rizwan Kaif
@Rizwan have a think about it, ExecuteCommand will run on the TM1 server, the OP is looking for a solution to something in the web client so this clearly isn't going to work.
@yng I don't think this is possible in a one step process as TM1 web is simply built to open excel files as websheets. A 2 step process is possible though: first hyperlink to open as websheet then export to open in excel.
- rkaif
Yes, Lotsaram....thats why I asked OP about the location of the file....and I did said that ExecuteCommand will only run the desktop app.lotsaram wrote:@Rizwan have a think about it, ExecuteCommand will run on the TM1 server, the OP is looking for a solution to something in the web client so this clearly isn't going to work.
Cheers!
Rizwan Kaif
Rizwan Kaif
I'm sorry but personally i'd like to be gay the way mrs brady describes it.Hi gays!
[in brady sequel]
Sub xlObj0(xlCG As Boolean)
If xlCG Then '} if using existing xl
xlApp.Visible = True '}
xlApp.EnableEvents = True '}
xlApp.DisplayAlerts = True '}
Else '}
xlApp.Quit '} quit if new xl created
End If '}
Set xlWkSh = Nothing
Set xlWkBk = Nothing
'Set xlApp = Nothing 'this also removes xl !?!
End Sub
Function xlObj1(pxlObj As String, pAlert As Boolean, pVis As Boolean, _
pEvent As Boolean, Optional pWin As Integer = xlMinimized)
Dim xlFound As Boolean, gErr As Boolean
On Local Error GoTo xlERR 'only sets xlobj
Select Case pxlObj '} get or create
Case "c" '}
xlFound = False
Set xlApp = CreateObject("excel.application") '}
Case "g" '}
xlFound = True
Set xlApp = GetObject(, "excel.application") '}
Case Else '}
End Select '}
xlApp.DisplayAlerts = pAlert ' turn off app Dialogs
xlApp.Visible = pVis '}
xlApp.EnableEvents = pEvent '}
xlApp.WindowState = pWin
xlObj1 = xlFound 'using existing or new xl
Exit Function
xlERR:
Debug.Print Err.Number; Err.Description
If Err.Number = 429 Then '} 429 = ActiveX component can't
Set xlApp = CreateObject("excel.application") '} create object
xlFound = False
Else
MsgBox Err.Number & " : " & Err.Description '} diplay an unknown Error
gErr = True '} flag error to calling sub
Exit Function
End If
Resume Next
End Function
Yeon
yng
- Excel Version: 2013
Thanks all for answers.
I will explain more in detail, what task.
Users work in TM1Web through IE which start on the terminal server. Whether there is a method, from the input form (published WorkSheet) to start on the terminal server in session of the user other xls-file with data TM1, but already in "thick" MS Excel.
On a hyperlink the xls-file opens, but as WorkSheet in TM1Web. It, unfortunately, doesn't approach.
Thanks.
Thanks.
As explained TM1 web is doing this because that's what it is designed to do. You have 2 options, either be happy with a 2 setp process to first open the excel file as a websheet then use the export menu in TM1 web to open the file in Excel. Or you need to find the follow hyperlink java script function within your TM1 web directory and edit the function.yng wrote:Thanks all for answers.
Thanks.
