When working with contributor in TM19.5.1, an error is encounted like, An error created by TI.
Thanks and regards.
Application Deploy error
- OLAP Product: IBM COGNOS TM1
- Version: 9.5
Re: Application Deploy error
The error exactly is
An error generated by TI function.
thanks and regards.
thanks and regards.
- Excel Version: Office 2010
It's a little difficult to help when you provide so little information. As with the Rules query you had, you can't just post the error message because there can be multiple possible causes.
- Version: 9.5
When i traced this error, through log files i found this causes:-
}tp_create_planning_artifacts. Error line for this process in Prolog Tab is
cSystemConfigDim=cControlPrefix|'tp_system_config';
- Martin Ryan
Can you post both the error and all the TI code in the prolog?
As noted in your other post error message can be a little inaccurate so you need to provide some context.
- Version: 9.5
Message log:
122960 Error TM1.Process Process"} tp_create_planning_artifacts":: Execution was aborted.Erro File:<TM1 process error_20110404050114_}tp_create_planning_artifacts.log>
Error:prolog procedure line(52):Process error
Even i tried personally creating a cube through text IN Ti it showed error likr dimesion failed, i was not able to create the cube.
- Martin Ryan
I'll try one more time.
Please post your error log. Put it up as an attachment so we can get the whole context.
Please post your ENTIRE prolog from the offending TI process.
