Line 43: Syntax Error on or before;
!roles, !Budget version,
invalid string expression
Rule could not be attached to the cube ,but changes are saved.
This was the error i am getting.
- Michel Zijlema
- OLAP Product: TM1, PALO
Re: Syntax Error on or before
I assume you have a question on this. If so, perhaps it's a good idea to share some more information, f.i. the complete rule that the error applies to.viswaraju wrote:Line 43: Syntax Error on or before;
Michel
- rkaif
- Version: 9.1 or later
With the error messages generated by Rules Editor, I have noticed that most of the time Line # mentioned is not exactly correct (specially when your rule spans to multiple lines). Therefore we have to look at the complete Rules to debug the errors.viswaraju wrote:Line 43: Syntax Error on or before;
As stated by Michel, you will have to post the complete Rule.
Cheers!
Rizwan Kaif
Rizwan Kaif
This is particularly true when you forget the semicolon at the end of a line: the line number stated will generally be the next line number after the offending line.rkaif wrote:With the error messages generated by Rules Editor, I have noticed that most of the time Line # mentioned is not exactly correct (specially when your rule spans to multiple lines). Therefore we have to look at the complete Rules to debug the errors.
But the message box states that a semicolon is missing so that should be easy to verify.
Not always; I got one just yesterday where I copied a block, just missing the semi-colon, and the error message that I got on compile was that an equals sign was missing. The level of trust that you can put in TI error messages may be higher than zero, but not by much.Wim Gielis wrote:This is particularly true when you forget the semicolon at the end of a line: the line number stated will generally be the next line number after the offending line.rkaif wrote:With the error messages generated by Rules Editor, I have noticed that most of the time Line # mentioned is not exactly correct (specially when your rule spans to multiple lines). Therefore we have to look at the complete Rules to debug the errors.
viswaraju
- OLAP Product: IBM COGNOS TM1
- Version: 9.5
not like missing semi colon, here it was in feeding cube it has one more dimension than the rule written cube. I can not able to feed the extra dimension,please any suggestions for me.
Thanks and reagrds.
Thanks and reagrds.
What element in that extra dimension contains the rules-calculated values? Feed to that particular element (when it comes to that dimension).viswaraju wrote:not like missing semi colon, here it was in feeding cube it has one more dimension than the rule written cube. I can not able to feed the extra dimension,please any suggestions for me.
Thanks and reagrds.
