TM1 server error regarding feeders and cube dates
Posted: Mon Mar 28, 2011 8:06 pm
Greetings:
We're running 9.5.1 and recently had our server crash at night. Just today, I attempted to restart the server and the restart was nearly complete when the service completely stopped. A quick check of the log file showed the following error:
Unfortuantely, the server takes quite a while to restart after this error occurs as it reloads all of the feeders.
I tried searching for a solution and came up with http://publib.boulder.ibm.com/infocente ... files.html but it states that this can happen if someone manually copies feeder or cube files, which hasn't been done.
Does anybody know of any other reason this may occur or how to prevent it from reoccurring in the future?
Invalid feeder file detected for cube "QAD" reason: feeder file date is older than cube date
All persistent feeder files will be deleted and server will shut down
Restart server to re-load database.
Phase 1 of server load failed
