IBM Cognos BI Developer Edition &
IBM Cognos Express
and install it.
i would want to test the new Cognos 10 using TM1 as my datasource. As there isnt any trial edition for Cognos TM1 9.5, therefore i downloaded cognos express so that i can use the TM1.
My question is can i connect Cognos BI with TM1 that comes with Cognos Express ?
i do not have any problem creating a connection from IBM Cognos Express Manager to TM1.
but when i try creating a connection from IBM Cognos BI Developer Edition Manager to TM1 it gives the following error msg.
would like to find out if i am able to get it working using those two combination ?
http://test-k81kc88178:9300/p2pd IBM Cognos TM1 / Compatible Failed TM1-ERR-0050 An attempt to initialize the TM1 API failed. The TM1 error code is 502. The TM1 error message is "Could not load tm1api.dll due to: The specified module could not be found. ".
http://test-k81kc88178:9300/p2pd http://test-k81kc88178:9300/p2pd IBM Cognos TM1 / Dynamic Failed XMD-CON-0001 Connect failed with error message: TM1-ERR-0050 An attempt to initialize the TM1 API failed. The TM1 error code is 502. The TM1 error message is "Could not load tm1api.dll due to: The specified module could not be found. ".
