Chore that write to Security Cubes
appleglaze28
Post by appleglaze28 »
Just a quick question...are chores that requires writing to a security cube restricted from being done? Cause I assume that chores are ran as a Admin User so when it run it should update the security cubes...but how come...it says that Data Source line (1) Error: Data procedure line (8): Execution was aborted. No Security Access for "CellPutS".
The process reads the attribute of a dimension to determine which groups have WRITE Access on that dimension.
What can be my alternate solution to do this without depending on the admin.
qml
Excel Version: 2007 - 2016
Re: Chore that write to Security Cubes
Post by qml »
You need to switch on Security Access for the process(es) that attempt to make any security changes. More on the subject here:
http://publib.boulder.ibm.com/infocente ... tyDat.html
Kamil Arendt
Yet again appleglaze28 you have astounded me. You needn't look so far as the IBM library but at the answer to your own question posted not so long ago.
http://www.tm1forum.com/viewtopic.php?f=3&t=3919
(Note to site admins: this question comes up an awful lot, should probably add it to processes and/or security section of FAQ)
lotsaram wrote:Yet again appleglaze28 you have astounded me. You needn't look so far as the IBM library but at the answer to your own question posted not so long ago.
Yeah, but is it ever asked by more than one person? :?
Duly noted; I'll gather up links to the relevant threads and documents when I have a moment.
