Attribute Error
John Hobson
OLAP Product: Any
Version: 1.0
Excel Version: 2020
Attribute Error
Post by John Hobson »
A client has a cube which is showing "error" against 3 attributes in the properties window.
There is no rule associated with it - Does anyone have any idea what might be causing it to display "error"?
I have never seen this before.
J
John Hobson
The Planning Factory
Re: Attribute Error
Have you checked for duplicate alias? Can't think of anything else unless there are weird chars that the properties pane can't display.
John Hobson
OLAP Product: Any
Version: 1.0
Excel Version: 2020
Re: Attribute Error
Well I'm doing this remotely so I'll have to ask them to check.
From the screen shot it was every N level throwing an error so I doubt it's duplicate aliases but thanks for the idea
If it is is I'll be back eating humble pie shortly :D
John Hobson
Re: Attribute Error
John Hobson wrote:Hi
I've seen it once... when attributes were populated by DBS formulas which were indeed sending an Error expression.
In other words, I'd browse the attributes cube and see whether the attribute values really ARE "Error".
John Hobson
OLAP Product: Any
Version: 1.0
Excel Version: 2020
Re: Attribute Error
I've already told them to check the }cube.
The DBS is indeed a potential cause I guess - thank for that idea
J
John Hobson
Andy Key
Version: 2.5 to PA
Excel Version: Lots
Re: Attribute Error
Post by Andy Key »
If the attributes cube looks fine, but the attribute viewer still shows errors, you could check the dimension itself and see if you've got any strange - possibly blank looking - elements, or elements that appear to be duplicates.
I've seen something similar where a dimension has become corrupted by having multiple elements made up of non printable characters. They originally got into the dimension when the source data file was created using the wrong character set. Cube viewer still worked fine, dimension editor fine, subset editor fine, but try and view the attributes through the Edit Attributes interface and the whole thing threw a wobbly, shifted all the attributes around and then complained about duplicate aliases that it had caused itself.
Fortunately the client only ever did attribute maintenance via the attributes cubes as the editor took too long to load anyway. But I think that was another topic!
Andy Key
Martin Erlmoser
OLAP Product: TM1, Cognos Express,..
Version: 9.1.4 FP1
Re: Attribute Error
Post by Martin Erlmoser »
J
is it correct that you also can't access these elements via rule / dbrw ?
tm1version?
Steve Vincent
Version: 10.2.2 FP1
Re: Attribute Error
Post by Steve Vincent »
Nope, i've changed values in the element attributes cube by both rules and DBRW methods in past. Only time i've seen error messages was when the rule i was testing went wrong, or the DBRW was sending duff data."Error" is normally and Excel type of message so i'd have a look at whats populating the attributes.
macsir
Version: PAL 2.0.9
Re: Attribute Error
Post by macsir »
We have this situation today and from the source table column, I found out that there is Horizontal Tab in the end of the string.
I use regexp_replace(string, CHR(09), null) to replace it and works fine.
