Action Button New Parameters Not Showing
PlanningDev
Version: 2.0.5
Post by PlanningDev »
I have an action button that is used to run a TI with parameters that are linked to cells in the excel file. I added a new parameter to the TI but I cant get the button to show the new parameter? Do I have to recreate the action button? If so this is a huge pain the in rear as I have to map 20 some parameters every time I do this.
Re: Action Button New Parameters Not Showing
PlanningDev wrote:I have an action button that is used to run a TI with parameters that are linked to cells in the excel file. I added a new parameter to the TI but I cant get the button to show the new parameter? Do I have to recreate the action button? If so this is a huge pain the in rear as I have to map 20 some parameters every time I do this.
Yes it's a huge pain. Been there done it. You may not have to recreate the action button, you can select another process, then exit out of editing the action button properties then reselect the action button. (You will still have to re-enter all the params so you may as well just recreate the button!)
PlanningDev
Version: 2.0.5
Thanks for the reply. Is it me or does TM1 have a few issues with data and caching etc? The TI processes sometimes don't take changes unless I hit save a couple times or close and reopen.
