dbr or dbs or dbsw stop working
MSidat
OLAP Product: TM1, PA
Version: PAL 2.0.8
Post by MSidat »
Hi all.
I have an issue where my dbr's stop working in excel 2003. We are basically using vba to run a series of TI's after taking parameters from the user and also reading and writing back to a series of datapoints in tm1, not more than 100.
Now the Tis continue to run which means the connection is still open but the dbr or dbsw or dbs do not work until I restart Excel and in the meanwhile they come up with either key error or error 2042. I log in as admin so security should not be an issue. Like I said on restart of Excel it works fine.
Any ideas what it could be.
cheers.
Always Open to Opportunities
suhamore
Version: 9.1 SP4+ 9.4.1 FP3+ 9.5.2 FP1
Excel Version: 2003 + 2010
Re: dbr or dbs or dbsw stop working
Post by suhamore »
I hope you are calling TM1RECAlC function in vba after the TI execution
ellissj3
Version: 9.0 - 10.2
Post by ellissj3 »
I have seen this error and sometimes adding Activeworkbook.calculate after the TM1Recalc has worked
Another solution is to go through each sheet and do the following
Application.run "Tm1recalc1"
Activesheet.calculate
MSidat
Version: PAL 2.0.8
Post by MSidat »
Usually yes we do call the TM1Recalc or Tm1recalc1 function. BUt the thing is the Dbr I am reffering it is actually within my VBA code and not on the workbook or in a sheet i.e. I am putting in a application.run("DBR", etc etc etc) function and it just does not work. I am still connected to TM1, Ti executes but the DBR just stop working via the application.run routine and the sheet itself. only an excel restart fixes the issue.
MSidat
Version: PAL 2.0.8
Post by MSidat »
Figured this out.
Had to put an:
Application.Run ("M_Clear") before my DBR.
As just prior to this the DImension was changed by another TI so the M_Clear needed to be called to reload and refresh the dimensions in memory. (Possibly??!!!)
paulsimon
Version: PA 2.0.5
Post by paulsimon »
Yes M_CLEAR seems likely. Excel caches up some of the TM1 data, and using the M_CLEAR macro can be used to force Excel to refresh its local cache of TM1 data. I have also used it in the past to get Dynamic MDX subsets to refresh.
