Hello all,
i try to publish TM1 Excel Perspectives Sheets containing VBA-Functions to Tm1 Web as application-files. My problem is, that the VBA-functions don't work in the TM1-Web. Can u guys help me solving that problem or isn't it possibel to use this functions in the Web?
Thank you in advance!
VBA-Functions in TM1 Web
Re: VBA-Functions in TM1 Web
TM1 Web does not have a live VBA interpreter so Excel VBA is not supported. The docs are reasonable clear about this. It's a shame I agree.
- Steve Vincent
- Version: 10.2.2 FP1
indeed, TM1web is a VBA free zone, which is why we cannot use it. 9.4 and the much improved Dynamic Slices / Active Forms might be an option tho, depending on what it is you are trying to do.
Herman Moller
It depends on what you are trying to achieve with your VBA.
If you are on 9.1+ you will be able to use Action Buttons.
As to quote the TM1 9.1 release notes:
Action Buttons
"TM1 9.1 offers the ability to create and define an Action button which enables you to build contextual Websheet navigation and TI process ‘launch’ buttons into your Excel worksheets and TM1 Web applications."
Action Buttons
ok thank you guys. I suspected that result but i couldnt believe it. I have different problems to solve.
One task is to create a checkbox, which gives a "select all" for all other checkboxes by click. Is there a way to do that without VBA?
Thank you again in advance
I wouldn't think it could be done without VBA and therefore not in TM1 Web.
