Option to NOT log when a TI / Chore runs
Posted: Thu Nov 06, 2008 2:06 pm
by Steve Vincent
An easy way to track user activity on TM1 is to run a tiny TI that checks the "ACTIVE" property of a client and adds the current date to a cube for anyone logged in. Currently we do this once every 30 mins, but thats not always enough to ensure you catch each user. I'd like to increase the frequency to every 10 or maybe 5 mins, but i know that everytime it runs the logs will get clogged with "2008/11/06 13:53:54:Process "zLast Logged On" finished executing normally" type messages.
I'm almost certain this can't eb done, but is there any way to not log the running of the chore / ti to stop the logs getting silly sizes?
Re: Option to NOT log when a TI / Chore runs
Posted: Thu Nov 06, 2008 2:10 pm
by Steve Rowe
I don't think so unless it's very new. I've been asking for this for ages so that we can increase performance of calling 1 TI from another...I haven't had chance to investigate but I believe 9.4 has changes to the logging functionality but I have not heard if this is included.
Posted: Fri Nov 07, 2008 9:50 am
by David Usherwood
What about running Performance Monitor and processing the }StatsbyClient data? I accept it wouldn't capture users who logged on and did nothing - but surely they wouldn't bother. Maybe need to apply some judgement to the result. _OR_ go back to Iboglix and suggest they extend the logic to capture logons and logoffs.
Posted: Fri Nov 07, 2008 10:05 am
by Martin Ryan
Which version are you running? If it's one of the early versions you can't get into the back of the tm1s.log because it's locked, but in 9.x I think tm1server.log can be opened.
So, if you're 9.x, you could try running a batch file or parser or whatever to open up the log file every hour or so and delete any lines with reference to your TI process.
Martin
Posted: Fri Nov 07, 2008 11:06 am
by mattgoff
Martin Ryan wrote:Which version are you running? If it's one of the early versions you can't get into the back of the tm1s.log because it's locked
You can use BareTail to read/watch locked files.
Matt
Posted: Sat Nov 08, 2008 5:59 pm
by Eric
I activated the transaction log on the status field on the }CLientProperties cube
I have a record of every log on and log off for all my users.
Posted: Mon Nov 10, 2008 9:16 am
by Steve Vincent
Yes, we already use the }ClientProperties cube to track the users with a TI, but that uses the "live" status when the TI runs rather than what's being logged. I've started to write some stuff to parse the logfiles in the data directory and extract all those events with a view to loading that to my tracking cube. I'll post what i complete in case anyone else finds it useful.
Posted: Mon Nov 10, 2008 9:53 pm
by David Usherwood
We'll check it out, but I think Eric's wheeze of logging }CubeProperties is neat. Then read the logfiles as Steve V suggests and you're in. (Steve, what are you thinking of doing it with? I feel a perl moment coming). Would be useful if the _vendor_ provided this type of thing though...
Posted: Tue Nov 11, 2008 12:53 pm
by bihints.com
Matt
RLY? I just tried with BareTail free version http://www.baremetalsoft.com/baretail/download.php?p=m and it failed to open the locked tm1smsg.log (9.0.3)
Posted: Wed Nov 12, 2008 10:52 am
by Steve Vincent
David Usherwood wrote:We'll check it out, but I think Eric's wheeze of logging }CubeProperties is neat. Then read the logfiles as Steve V suggests and you're in. (Steve, what are you thinking of doing it with? I feel a perl moment coming). Would be useful if the _vendor_ provided this type of thing though...
PERL indeed :lol: A colleague is much better versed in the ways of PERL than i and had already written a script for searching for strings in log files (much quicker than using the TM1 search when looking over a large date range and doesn't hold up users whilst doing it) so i have used that as a base for finding all the log in / log out transactions. Still working on the TI part, but will share once i have it working.
