Getting Attribute and Allias value in a dimension
winsonlee
OLAP Product: Cognos Express
Version: 9.5
Post by winsonlee »
Currently i am only able to get the store number which is the element that i have selected. But i would like to have more information about the store which is stored as the attribute within customer dimension.
For example I would like to have my table to look as such.
State StoreNo StoreName Sales Sales Unit
Vic 8088 xxx $55 10
Nsw 4512 yyy $34 3
the code provided is in c# and i am using the TM1 api to obtain the data. help will be appreciated. thanks.
                table = new DataTable();
                TM1AdminServer admin = TM1ConnectionAgent.TM1ConnectionOpen();
                TM1Server myServer = TM1ConnectionAgent.TM1ServerOpen(admin);
                string mdxExpression = string.Empty;
                DataColumn[] keys = new DataColumn[1];
                DataColumn column = new DataColumn();
                column.ColumnName = "State";
                table.Columns.Add(column);
                keys[0] = column;
                    mdxExpression = "SELECT{[Data Fields].[Sales], [Data Fields].[Sales Unit]} ON COLUMNS, {ORDER({[Customers].Children}, ([Data Fields].[Sales]) , DESC)}  ON ROWS FROM [Sales Cube] WHERE ([Year].[" + Year + "],[Version].[Final],[Products].[All Products],[Period].[" + Period + "])  ";
                TM1MdxView MyTm1DataView = new TM1MdxView(myServer, mdxExpression);
                TM1MdxAxis MyMdxColAxis = MyTm1DataView.GetAxis(0);
                int MyMdxColTupleCount = MyMdxColAxis.TupleCount;
                for (int i = 0; i < MyMdxColTupleCount; i++)
                    string columname = MyMdxColAxis.GetAxisValue(i, 0, 1).ToString();
                    table.Columns.Add(columname, typeof(decimal));
                TM1MdxAxis MyMdxRowAxis = MyTm1DataView.GetAxis(1);
                int MyMdxRowTupleCount = MyMdxRowAxis.TupleCount;
                for (int y = 0; y < MyMdxRowTupleCount; y++)
                    DataRow rowNew = table.NewRow();
                    rowNew[0] = MyMdxRowAxis.GetAxisValue(y, 0, 1);
                    object cellValue;
                        cellValue = MyTm1DataView.GetCellValue(y, i);
                        rowNew[i + 1] = cellValue;
                    table.Rows.Add(rowNew);
                MyMdxColAxis.Dispose();
                MyMdxRowAxis.Dispose();
                admin.LogoutAll();
                MyTm1DataView.Dispose();
                admin.Dispose();
rkaif
OLAP Product: IBM Cognos TM1
Version: 9.1 or later
Excel Version: 2003 or later
Re: Getting Attribute and Allias value in a dimension
Post by rkaif »
By using the ATTRS() you can get the String Attribute fore the specified element. Syntax is:
ATTRS(dimension, element, attribute)
Cheers!
Rizwan Kaif
yyi
Post by yyi »
see control cube for attribute list and find index i
vDimensionElement[0].Attributes.Value.ToString()
have you come across a subset list where the code breaks and the message is:-
Cannot create attribute value for "my attr-01" attribute, parameter is ERROR.
Yeon
