64 bit Access ODBC connection
Posted: Fri Feb 25, 2011 12:18 pm
Apologies if this is a basic question, but it's something I have not come up against before
On Server A, I have 64 bit TM1 9.4 MR1 installed. I have configured a 64-bit ODBC Access driver and can quite happilly connect to a database on the same server
If I move the Access DB to Server B, and reconfigure the ODBC connection on Server A to point to Server B I get a connection error when opening a TI process that uses this connection. The error message is "Unable to open connection to Database".
The username that I am logged in on can map a drive on Server B to Server A succesfully. Server A is running Windows Server 2003 R2 64 bit (SP2)
I tried to put the Access DB on to another server - Server C - and tried to connect to this instead but got the same error.
What should I be looking at to resolve this?
Thanks in advance
Anthony
Thanks in advance
Anthony
