In an Excel spreadsheet, using VB or Excel Macro code, how can we check if a user is connected to a TM1 server or not?
This is to avoid running n_disconnect or n_connect blindly without checking if the user is really connected or not.
Any help would be appreciated.
How to check if a user is connected to TM1 server in Excel?
- Martin Ryan
Re: How to check if a user is connected to TM1 server in Exc
Try this one: http://applixforum.olapforums.com/viewP ... tion#36072
Another way is to just do a DBR to a cube that all users have access to. (Create one if you need to.) If it returns the expected value, they're connected.mce wrote:Hi,
- Oratia623
- OLAP Product: TM1/PA/CA
- Version: V7.x to 2.0.9+
- Excel Version: All
I use the worksheet function: TM1User("ServerName"). If it returns a blank - then they are not connected.
Though I am not sure in what version this function was introduced (I am using TM19.5.1)
Paul Williamson
____________________________________________________________________________________
I came. I saw. I did not concur.
9.1 SP2.Oratia623 wrote:I use the worksheet function: TM1User("ServerName"). If it returns a blank - then they are not connected.
Wow that post was a blast from the past, shame there are no dates on the old Applix forum threads.Martin Ryan wrote:Try this one: http://applixforum.olapforums.com/viewP ... tion#36072
