Active Forms breaks with =IF() logic in referenced cell
Posted: Mon Feb 14, 2011 6:37 pm
Hello all.
I'm finding that an IF() formula residing in the referenced cell of a DBRW() is causing AF to produce zeros. Using a hard value or even a non-IF() formula appears to work. The IF() breaks it though.
For example, I have a finLocation dimension with a child of "10001" and a parent of "All Locations". A DBRW() on my AF sheet references a cell containing the finLocation element. In that cell I have =IF( scenario="Historical", "All Locations", "10001"). This breaks the sheet, meaning that all of the DBRW()s return zeros. However, if I just type in "Historcal" to the referenced cell then I'm good to go. Likewise, typing in "10001" in to the referenced cell produces values as well. It appears to just be the IF logic doing that.
I checked this thread trying to find a similar issue ( http://forums.olapforums.com/viewtopic.php?f=3&t=4163 ) without luck. There are a few more thread about zeros on Active Forms, but nothing about this in particular.
Any thoughts?
Chris
Any thoughts?
Chris
