Deleting log-files older than < x > days with TI
Marcus Scherer
Post by Marcus Scherer »
At the costumer site no admin ever observed and probably never will observe the log-files. Thus they can be regularly deleted, assuming a regular backup of the log directory on tape is in place! Maybe you're interested in it.
- valid for the actual decade (searching for "tm1s201*.log")
- Windows OS
602_delete_log_files.pro
(1.69 KiB) Downloaded 1434 times
Mike Cowie
Version: Anything thru 11.x
Re: Deleting log-files older than < x > days with TI
Post by Mike Cowie »
Marcus:
Thanks for posting this. There are also some DOS-based ways of doing this, too, if you'd like to use some other non-TI scheduler, or would like to use a single batch file/command from TI (using ExecuteCommand). One of the DOS command methods I've used takes advantage of the Forfiles command and looks something like this (this one clears out Cognos Express logs 21 days or older):
cmd /c Forfiles -p "C:\Program Files (x86)\IBM\Cognos Express\logs\express" -s -m "*.log" -d "-21" -c "cmd /c del /q @path"
A bit cryptic at first glance, but 1 command takes care of it all.
Some notes on the ForFiles command, if interested in learning more about it:
http://technet.microsoft.com/en-us/libr ... S.10).aspx
Mike
Mike Cowie
QueBIT Consulting, LLC
BigG
OLAP Product: IBMPA
Version: PA 2.0 Cloud
Post by BigG »
Hi there, just jumping in on this post, if you run that cmd arethere any .log files that are located in C:\Program Files (x86)\IBM\Cognos Express\logs\express that you would want to consider retaining?
Note we are on cognos express too
GG
ADW
OLAP Product: Cognos Express
Version: 9.5
Post by ADW »
This question has just popped up for us.
We want to delete older log files but are not sure which ones we need to keep hold of.
Also have Cognos Express.
BigG
OLAP Product: IBMPA
Post by BigG »
Hi ADW, we ended up just going for every .log file 3 weeks or older deleted once a week using the script from Marcus. Also restart service at same time
GG
ADW
Version: 9.5
Post by ADW »
Thanks for that.
I was worried that deleting the cogserver.log file would cause a problem, but I guess that file never gets older than the last time Cognos was used.
