I've set PerformanceMonitorOn=F in the .cfg file put I still get the same error.tm1server.log wrote: 5304 INFO 2008-10-30 11:10:20,186 TM1.Server Data Directory: c:\tm1data64bit\data
5304 INFO 2008-10-30 11:10:20,186 TM1.Server Admin Host: tm1host
5304 INFO 2008-10-30 11:10:20,186 TM1.Server Logging Directory: c:\tm1data64bit\logs
5304 INFO 2008-10-30 11:10:20,186 TM1.Server Configuration Directory: c:\tm1data64bit
5304 INFO 2008-10-30 11:10:20,186 TM1.Server Port: 14719
5304 INFO 2008-10-30 11:10:20,186 TM1.Server Client Message Port: 0
5304 INFO 2008-10-30 11:10:20,186 TM1.Server Export Admin Server Certificate: 0
5304 INFO 2008-10-30 11:10:20,186 TM1.Server Admin Server Certificate Authority: C:\Program Files\Cognos\TM1\bin\ssl\applixca.pem
5304 INFO 2008-10-30 11:10:20,186 TM1.Server Admin Server SSL Cert ID: tm1adminserver
5304 INFO 2008-10-30 11:10:20,186 TM1.Server Admin Server SSL Cert ID: tm1adminserverSSL Mode:
5304 INFO 2008-10-30 11:10:20,186 TM1.Server Export Server Certificate:
5304 INFO 2008-10-30 11:10:20,186 TM1.Server SSL Certificate: C:\Program Files\Cognos\TM1\bin\ssl\tm1svrcert.pem
5304 INFO 2008-10-30 11:10:20,186 TM1.Server Certificate Authority: applixca.pem
5304 INFO 2008-10-30 11:10:20,186 TM1.Server Client Export Server Certificate:
5304 INFO 2008-10-30 11:10:20,186 TM1.Server DH 512 File: C:\Program Files\Cognos\TM1\bin\ssl\dh512.pem
5304 INFO 2008-10-30 11:10:20,186 TM1.Server DH 1024 File: C:\Program Files\Cognos\TM1\bin\ssl\dh1024.pem
5304 INFO 2008-10-30 11:10:20,186 TM1.Server Private Key Password File: C:\Program Files\Cognos\TM1\bin\ssl\tm1cipher.dat
5304 INFO 2008-10-30 11:10:20,186 TM1.Server Password Key File: C:\Program Files\Cognos\TM1\bin\ssl\tm1key.dat
5304 INFO 2008-10-30 11:10:20,186 TM1.Server Security Mode:
5304 INFO 2008-10-30 11:10:20,186 TM1.Server Start time: Thu Oct 30 2008 11:10:20 AM
5304 ERROR 2008-10-30 11:10:20,186 TM1.Server Failure initializing Performance Monitor: 80070002
The data is from an existing 8.4.5 model so it's got to upgrade to unicode, but I'd have thought that should be straightforward?
Running the shipped-with Planning Sample is ok, so I guess it must be something to do with my cfg file or data set. But my cfg file is virtually the same as the working Planning Sample.
My cfg file:
TIA,tm1s.cfg wrote: [TM1S]
ServerLogging=F
SecurityPackageName=Kerberos
IntegratedSecurityMode=1
UseSSL=T
ServerName=running64bitInstall
DataBaseDirectory="C:\TM1Data64Bit\Data"
LoggingDirectory="C:\TM1Data64Bit\Logs"
AdminHost=TM1
PortNumber=14719
ClientMessagePortNumber=12346
Language=ENG
SaveTime=
DownTime=
ProgressMessage=True
AllowSeparateNandCRules=T
ClientVersionMinium=844
