Hi there,
We know DBRA() function will bring back the attribute value for a element. But is there a way you can dynamically filter results based on an attribute referenced in the report? eg. a picklist of text attribute allows for the returned subset to filter based on the attribute value. Is this a MDX formula that can be built into the report ? Havent found an answer yet so just guessing...
Shoot any questions if this is not clear.
thanks in advance
G
Filter by attribute in worksheet? TM1 web
- Version: 2.5 to PA
- Excel Version: Lots
Re: Filter by attribute in worksheet? TM1 web
Assuming you are using Active Forms, then your TM1RPTROW formula can use an MDX statement as the basis for its selection. This MDX statement can then contain a reference to the cell that contains your chosen attribute.
Andy Key
