What does Application.EnableEvents = False do in VBA?
Can you Describe what the code below is doing?
{ EXCEPT( {[JDE_Account].[CorpCostReport]}, { [JDE_Account].[9022] }) }
Thank you in advance.
Radhika
VBA & Business rules.
Re: VBA & Business rules.
The EnableEvents property enables or disables events. An event is an action, like Change, that occurs in Excel, usually the result of a user action. If an event procedure is defined for that event, Excel will automatically execute that code if EnableEvents is True. If EnableEvents is False, the code is not executed. This is a way of stopping dependent controls that may get you into an infinite loop when something changes programmatically.Radhika wrote: What does Application.EnableEvents = False do in VBA?
This would only make sense is CorpCostReport was a subset. Then, this would use the subset called CorpCostReport and remove account 9022 from the list if it existed.Radhika wrote: Can you Describe what the code below is doing?
If CorpCostReport had the following items:
- 1050
1070
3050
9000
9022
9134
9256
- 1050
1070
3050
9000
9134
9256
Radhika
- Version: v9.4.1
- Excel Version: Microsoft Excel 2003
Hi Blackhawk,
Thank you very very much for the detailed explanation.
Thank you,
Radhika
Thank you,
Radhika
