Displaying sandbox name in excel cell
Posted: Thu Jan 20, 2011 9:57 am
by daveed
Does anyone have a way of returning an active sandbox name into an Excel cell? This is so we can print from Excel, displaying the sandbox name.
Re: Displaying sandbox name in excel cell
Posted: Thu Jan 20, 2011 11:54 am
Yes it is possible but not automatically without user intervention. If you are happy for the user to click an action button that runs a process containing the ServerActiveSandboxGet() and TM1User() functions then you can write to a string cell in a cube containing the }Clients dimension the name of the user's active sandbox and return the value of the cell in the Excel worksheet.
This is the only workaround I can think of.
Posted: Thu Aug 18, 2011 11:26 pm
by asingla83
Hi lotsaram,
I am trying to achieve the same - find a way to display active sandbox name in an excel. I tried your suggested workaround and it worked fine when I tested it using admin login. But the TI process fails to run for non-admin users. I have a changed the security setting for non-admin users and they have read access to TI process. The security access is checked when I right-click on the TI process. When a non-admin user runs the process, it gives following error:
" Error getting active sandbox - no ad-hoc sandbox capability has been granted"
I do not understand this error and unfortunately couldn't find anything on this error message from google search.
Any help on this from you or anyone on the forum is much appreciated.
Posted: Fri Aug 19, 2011 1:54 am
by Kyro
Why not create a custom VBA function which returns the sandbox name from the toolbar combo box?
This shouldn't be too hard and will be reliable, as whenever the combo box changes the worksheet would likely be refreshed thus refreshing the function in cell.
Posted: Fri Aug 19, 2011 5:38 pm
by asingla83
Kyro,
Thanks much for your response. Any help on how I can do it?
Posted: Sat Aug 20, 2011 3:52 am
by Kyro
If I get time this week I'll take a look but I'm pretty busy at the moment. Feel free to PM me after a week if I haven't come back with anything and we'll see if we're able to sort something out for you then.
Posted: Tue Aug 30, 2011 2:56 am
by Kyro
Function getSandbox() As String
Dim it As Long, ib As Long
For it = 1 To CommandBars.Count
If CommandBars(it).Name = "TM1 Sandbox" Then
For ib = 1 To CommandBars(it).Controls.Count
If CommandBars(it).Controls(ib).Caption = "" Then
Dim btn As CommandBarComboBox
Set btn = CommandBars(it).Controls(ib)
getSandbox = btn.Text
Exit Function
End If
Next ib
End If
Next it
End Function
You could make it a lot more stable than this by adding filters which ensure the correct control is selected. This is just a working starting point. Once you add this into a workbook you can use =getSandbox() within a cell and it will return the active sandbox.
Let me know how you get on.
Posted: Sat Oct 12, 2013 3:18 pm
by rduggs
Kyro wrote:Code: Select all
Exit Function
End If
Next ib
End If
Next it
End Function
Did this work for anyone? I am trying to use it in TM1 10.1, but haven`t had any success.
Any help would be greatly appreciated.
-RD
