Instal issues with 9.5.1 perspectives
Faizaln
Version: 9.1.1
Excel Version: 2000
Post by Faizaln »
Hi All
I am trying to install TM1 9.5.1 as stand alone on my PC. I am using the wizard to install perspectives.
I then connect perspectives to excel as an add on.
BUT...when TM1 tries to launch, it gets stuck on the introduction screen. This is very annoying as I have installed other versions of perspectives without issues.
any advice would be appreciated
regards
kpk
OLAP Product: TM1, CX
Re: Instal issues with 9.5.1 perspectives
Post by kpk »
2 ideas to check in the TM1 option:
Admin Host: is there any remote server listed there?
Connect to Local server at startup: is this option turned off?
Other hint: http://forums.olapforums.com/viewtopic.php?f=3&t=2223.
You can also try a search for "tm1p.ini" issues on this forum.
Best Regards,
Peter
TJMurphy
Version: PA 2.0.6 Local
Excel Version: Excel 2016
Post by TJMurphy »
If your Admin Host has an entry for a previous version of the server somewhere you get this "effect".
