We're running Tm1 9.1.4, noticed one of the views stopped working - "cube 'Billing Category' not found"! Had a look in architect and the cube had indeed totally vanished! This is a permenent cube, fairly small and uncomplicated. Initially I could not even find 'Billing category.cub', however I noticed that there is a Billing Category.cub$ file.
In the tm1 log I found this:
As you can see the cube rename failed a few days ago. The obvious solution seems to be remove the $ from the filename, and hopefully the cube will re-appear after the overnight restart.I was also reading http://forums.olapforums.com/viewtopic.php?f=3&p=5791 so I guess my questions are:5532 ERROR 2011-01-07 19:01:32,234 TM1.System.File sf_Rename: Failed to rename (d:\tm1data\abax\Billing Category.cub$) to (d:\tm1data\abax\Billing Category.cub). Errno: 13
5532 ERROR 2011-01-07 19:01:32,234 TM1.Commit CommitActionLog::SaveFiles() - Failed to rename file Billing Category.cub$ to Billing Category.cub
Has anyone experienced this before?
What are the possible causes and where could I find out what Errno: 13 is?
