Transfer data from attributes to cube with rules
tm1starter
OLAP Product: Tm1
Version: 9.5.1
Post by tm1starter »
Hello all,
I have the next problem;
I have a employee cube with the next dims (simplified);
- Employee
- EmployeeType (elements I and E)
- Measure (element FTE)
- Period
and the Employee dim has the next attributes;
- FTE (Value between 0 and 1)
- EmployeeType (Value I or E)
With a rule I want to fill the cube with the FTE's out of the attribs in the Emloyee dim, the FTE's should be the same in all months, for example
Dimension.
employee FTE EmployeeType
Employee1 1 I
Cube
EmployeeType I
Measure FTE
Period
01 02 03 ...
Employee1 1 1 1 ...
With a TI proces it's quite simple to load the cube, but how is it done with a rule?
I come this far;
['FTE' ] = DB('}ElementAttributes_Employee', !Employee, 'FTE');
But then the EmployeeType is not taken into account and on both I and E values are set.
I have tried this;
['FTE' ] = If( DB('}ElementAttributes_Employee', !Employee, 'EmployeeType')=!EmployeeType,
					DB('}ElementAttributes_Employee', !Employee, 'FTE'),
					0);
But this also doesn't work
Can someone help me :?:
Steve Vincent
Version: 10.2.2 FP1
Re: Transfer data from attributes to cube with rules
Post by Steve Vincent »
is it only the I type of employee you wish to fill the value for FTE? If so, try;
['FTE', 'I'] = DB('}ElementAttributes_Employee', !Employee, 'FTE');
tm1starter
OLAP Product: Tm1
Version: 9.5.1
It is not only the I type, I and E are used both.
I don not also want this one;
['FTE', 'I'] = IF(DB('}ElementAttributes_Employee', !Employee, 'EmployeeType')='I'
                       CONTINUE);
['FTE', 'E'] = IF(DB('}ElementAttributes_Employee', !Employee, 'EmployeeType')='E'
                       CONTINUE);
I want a general rule, so when I'm adding types there is no problem
tm1starter wrote:I have tried this;
0);
But this also doesn't work?
This should work but the problem is in your rule syntax. When comparing strings you use "@=". Change the above to:
['FTE' ] = If( DB('}ElementAttributes_Employee', !Employee, 'EmployeeType')@=!EmployeeType,
tm1starter
OLAP Product: Tm1
Version: 9.5.1
Indeed this works, Thnx!
I'm a bit shamed, about this error :oops:
