VBA Process Run Issue Encountered
Version: PA 2.0.7
Post by jim wood »
Guys,
I have used soem of the code that I found on the forum to try run a process from Excel. I have been happliy plugging away but I have now come across an erorr that I can't find. I'm getting a type mismatch. Can any of you guys see where my problem is?
Public Const c_ServerName = "tm1development"
Public Const c_AdminHost = "sjmb089as"
Declare Sub TM1APIInitialize Lib "tm1api.dll" ()
Declare Function TM1SystemOpen Lib "tm1api.dll" () As Long
Declare Function TM1ValPoolCreate Lib "tm1api.dll" (ByVal hUser As Long) As Long
Declare Sub TM1SystemAdminHostSet Lib "tm1api.dll" (ByVal hUser As Long, ByVal AdminHosts As String)
Declare Function TM1SystemServerNof Lib "tm1api.dll" (ByVal hUser As Long) As Integer
Declare Function TM1ValString Lib "tm1api.dll" (ByVal hPool As Long, ByVal InitString As String, ByVal MaxSize As Long) As Long
Declare Function TM1SystemServerConnect Lib "tm1api.dll" (ByVal hPool As Long, ByVal sDatabase As Long, ByVal sClient As Long, ByVal sPassword As Long) As Long
Declare Function TM1ValArray Lib "tm1api.dll" (ByVal hPool As Long, ByRef sArray() As Long, ByVal MaxSize As Long) As Long
Declare Sub TM1ValArraySet Lib "tm1api.dll" (ByVal vArray As Long, ByVal val As Long, ByVal index As Long)
Declare Function TM1ObjectListHandleByNameGet Lib "tm1api.dll" (ByVal nPool As Long, ByVal hObject As Long, ByVal iPropertyList As Long, ByVal sName As Long) As Long
Declare Function TM1ProcessExecute Lib "tm1api.dll" (ByVal hPool As Long, ByVal hProcess As Long, ByVal hParametersArray As Long) As Long
Declare Function TM1ValType Lib "tm1api.dll" (ByVal hUser As Long, ByVal Value As Long) As Integer
Declare Sub TM1ValErrorString_VB Lib "tm1api.dll" (ByVal hUser As Long, ByVal vValue As Long, ByVal Str As String, ByVal Max As Integer)
Declare Function TM1ValBoolGet Lib "tm1api.dll" (ByVal hUser As Long, ByVal vBool As Long) As Integer
Declare Function TM1SystemServerDisconnect Lib "tm1api.dll" (ByVal hPool As Long, ByVal hDatabase As Long) As Long
Declare Sub TM1ValPoolDestroy Lib "tm1api.dll" (ByVal hPool As Long)
Declare Sub TM1SystemClose Lib "tm1api.dll" (ByVal hUser As Long)
Public Function p_ExecuteTM1process(ByVal tm1process As String, ByVal parameters As Variant, ByVal login As String, ByVal password As String) As Boolean
' Author:
'           Jim Wood
' Parameters:
'           tm1process  -> Name of TM1 process
'           parameters  -> Array containing the parameters for the TM1process
'           login       -> TM1 loginname
'           password    -> TM1 password
' Function:
'           Executes TM1 process 'tm1process'
'           REMARK:
'               Expects the following constants to be declared and initialized:
'                   Const c_ServerName   'Name TM1 server
'                   Const c_AdminHost    'Hostname of TM1 server
' Return:
'           TRUE     -> Function succeeded
'           FALSE    -> Function failed
On Error GoTo AfterError:
    Dim nServerName As Long
    Dim hServerName As Long
    Dim nClientID As Long
    Dim nPassword As Long
    Dim Retlong As Long
    Dim voprocess As Long
    Dim hParametersArray As Long
    Dim iparamarray() As Long
    Dim nNrOfParams As Long
    Dim sprocessname As String
    Dim RetType As Long
    Dim ErrorCode As Long
    Dim nI As Integer
    Dim sErrMsg As String * 100
    'Connection
    TM1APIInitialize
    hUser = TM1SystemOpen()
    If hUser = 0 Then
        MsgBox ("Error opening the system")
        GoTo ExitFunction
    End If
    'Create pool
    pGeneral = TM1ValPoolCreate(hUser)
    If pGeneral = 0 Then
        MsgBox ("Error creating memory pool")
        GoTo ExitFunction
    End If
    'Admin host
    Call TM1SystemAdminHostSet(hUser, c_AdminHost)
    Retlong = TM1SystemServerNof(hUser)
    ' Locate server and connect
    nServerName = TM1ValString(pGeneral, c_ServerName, 75)
    nClientID = TM1ValString(pGeneral, login, 75)
    nPassword = TM1ValString(pGeneral, password, 75)
    hServerName = TM1SystemServerConnect(pGeneral, nServerName, nClientID, nPassword)
    sprocessname = tm1process
    nNrOfParams = UBound(parameters) + 1
    ReDim iparamarray(nNrOfParams - 1)
    'For each parameter
    For nI = 1 To nNrOfParams
        iparamarray(nI - 1) = TM1ValString(pGeneral, parameters(nI - 1), Len(parameters(nI - 1)))
    Next nI
    hParametersArray = TM1ValArray(pGeneral, iparamarray, nNrOfParams)
    'For each parameter
        TM1ValArraySet hParametersArray, iparamarray(nI - 1), nI
    Next nI
    voprocess = TM1ObjectListHandleByNameGet(pGeneral, hServerName, TM1ServerProcesses, TM1ValString(pGeneral, sprocessname, 100))
    Retlong = TM1ProcessExecute(pGeneral, voprocess, hParametersArray)
    RetType = TM1ValType(hUser, Retlong)
    If RetType = TM1ValTypeError Then 'TM1ValTypeObject Then
    'Return value is an error object
        TM1ValErrorString_VB hUser, Retlong, sErrMsg, 100
        Err.Raise vbObjectError + 514, , sErrMsg
    Else
    'Return value is a boolean value
        Retlong = TM1ValBoolGet(hUser, Retlong)
        If Retlong = 0 Then
            Err.Raise vbObjectError + 515, , "Process generated errors" & vbCrLf & "Check log file."
        Else
            'Process executed successfully
        End If
    End If
    p_ExecuteTM1process = True
ExitFunction:
    'DECONNECTION
    If pGeneral > 0 And hServerName > 0 Then
        Retlong = TM1SystemServerDisconnect(pGeneral, hServerName)
    End If
    'Destruction of pool
    If pGeneral > 0 Then
        TM1ValPoolDestroy (pGeneral)
    End If
    If hUser > 0 Then
        Call TM1SystemClose(hUser)
    End If
    Exit Function
AfterError:
    MsgBox "p_ExecuteTM1process: There was an error while executing process '" & tm1process & "':" & vbCr & vbCr & Err.Description, vbCritical, "Oops"
    Resume ExitFunction
End Function
Sub Button_proc_load()
    Call p_ExecuteTM1process("fwibble_proc", 0, "admin", "pear")
End Sub
Oratia623
OLAP Product: TM1/PA/CA
Version: V7.x to 2.0.9+
Excel Version: All
Re: VBA Process Run Issue Encountered
Post by Oratia623 »
*Disclaimer* I haven't any testing, but I believe the issue you are having is with the second variable you are passing to the p_ExecuteTM1process function from Button_proc_load.
The way the second variable is used in the function looks as if it is designed to be an array of parameters for the TI.
You have the following in Button_proc_load:
The second variable is not an array, I assume from this that the TI "fwibble_proc" has no parameters?
If you create an empty array and pass this through instead of 0, does it work?
eg:
Dim myparam(0) As Variant
Call p_ExecuteTM1process("pwtest", 0, "admin", "apple")
End Sub
Paul Williamson
____________________________________________________________________________________
I came. I saw. I did not concur.
Martin Ryan
Post by Martin Ryan »
If you've started with Mike Cowie's code (and it looks like you have) then the container for the parameters needs to be an array (specifically a ParamArray) and this array needs to be the last argument so the calling procedure can rattle off n parameters without getting confused by other parameters (c.f. http://forums.olapforums.com/viewtopic. ... 410#p15379).
Version: PA 2.0.7
Post by jim wood »
I have changed the parameters around and it looks like it runs but the process does not updat ethe cube. Very strange. It just goes to hour glass for a second and then comes back.
Version: PA 2.0.7
Post by jim wood »
My revised code:
Public Function p_ExecuteTM1process(ByVal tm1process As String, ByVal login As String, ByVal password As String, ParamArray parameters()) As String
' Author:
'           Jim Wood
' Parameters:
' Function:
'           REMARK:
' Return:
    Dim Retlong As Long
    Dim RetType As Long
    Dim nI As Integer
    'Connection
    TM1APIInitialize
    If hUser = 0 Then
        GoTo ExitFunction
    End If
    'Create pool
        GoTo ExitFunction
    End If
    'Admin host
    'For each parameter
    Next nI
    'For each parameter
    Next nI
    Else
        If Retlong = 0 Then
        Else
        End If
    End If
ExitFunction:
    'DECONNECTION
    End If
    End If
    If hUser > 0 Then
    End If
    Exit Function
AfterError:
    Resume ExitFunction
End Function
    Call p_ExecuteTM1process("fwibble_proc", "admin", "pear", "")
End Sub
Version: PA 2.0.7
Post by jim wood »
Guys,
I think I have narroed it down. I think for some reason it is not able retrieve the process (object) name correctly. Have any of you encoutnered this problem before?
Martin I dropped your code in to my test sheet and it failed at the object check stage:
ProcessHandle = TM1ObjectListHandleByNameGet(ValPoolHandle, ServerHandle, TM1ServerProcesses, TM1ValString(ValPoolHandle, ProcessName, 0))
  If TM1ValType(SessionHandle, ProcessHandle) <> TM1ValTypeObject Then
    RunTIProcess = "ERROR: Unable to access process " & ProcessName & "."
    GoTo Cleanup_API
  End If
I have run the debugger and both the SessionHandle and ProcessHandle are populated and I am logged in to my development server as admin,
Jim.
Marcus Scherer
Post by Marcus Scherer »
Hi Jim,
if you have no parameters in your process, set the following parameter to 0 (or modify determination of hParametersArray):
hParametersArray = TM1ValArray(pgeneral, iparamarray, 0)
This worked for me with your code.
HTH, Marcus
Mike Cowie
Version: Anything thru 11.x
Post by Mike Cowie »
jim wood wrote:Guys,
Jim.
Hi Jim,
Sorry for the late reply to this thread - have you verified that the server handle is also valid (an object)? If for some reason the server connection failed you will obviously not be able to get a handle to the TI process. Sorry if that's something you're already checking, but I didn't spot that in your code.
Mike
Mike Cowie
QueBIT Consulting, LLC
Version: PA 2.0.7
Post by jim wood »
Thanks for the suggestions guys. I'll have a look when I am able. The day job is getting in the way at the moment.
Version: PA 2.0.7
Post by jim wood »
Marcus Scherer wrote:Hi Jim,
HTH, Marcus
I have updated the code as suggested above and I am still not getting the same result as before. It look like it runs but the cube is not updated.
I'm going to try to run the process from another biox to see if it something to do with my dev server. (Which wouldn't be a suprise.)
Marcus Scherer
see attached the complete code, in case I oversaw another change. The API declarations I usually store in a separate module.
Marcus
API_declarations.txt
(35.91 KiB) Downloaded 450 times
proc_load.txt
(4.33 KiB) Downloaded 444 times
Version: PA 2.0.7
Post by jim wood »
Many thanks Marcus,
Jim.
