Active Form and last line format
Jonsulli
Version: 9.5
Post by Jonsulli »
With Active Forms, is there a way to create a dynamic line in the last row without using a format section ?
Many thanks for your help,
Jon
Oratia623
OLAP Product: TM1/PA/CA
Version: V7.x to 2.0.9+
Excel Version: All
Re: Active Form and last line format
Post by Oratia623 »
If you are trying to put a border at the bottom of your last row, you can achieve this by putting the border on the top of the row below the last line of the Active Form. This row is moved up/down when you drill up/down the row items in the Active Form. You would need to ensure that this row is included in the print area though.
Paul Williamson
____________________________________________________________________________________
I came. I saw. I did not concur.
Jonsulli
Version: 9.5
Post by Jonsulli »
Thank you very much !!! It works perfectly fine !!! :D
