I remember someone already asked about this before, I can't find the thread.
I want to try to create dimension for Department and Sub Department. And I'm not sure whether I only have to create one dimension with the Sub Department added as the child of the Department, or should I create a Department dimension and a Sub Department dimension? What are the benefits and the drawbacks of each approach?
Thanks before for your help guys.
Defining Dimension Structure
comma
- Version: 9.5.0 64-bit
- Excel Version: 2003 SP3
Windows Server 2003 Enterprise x64
Windows XP Pro 2002 SP3
Internet Explorer 7
Internet Explorer 7
Re: Defining Dimension Structure
The deciding question to my mind would be whether there is any prospect of a sub-department falling across multiple departments, or possibly moving between departments over time. If that's a possibility, then I would say that a sub-department is a separate and distinct characteristic of a value and warrants its own dimension.comma wrote:I remember someone already asked about this before, I can't find the thread.
If, on the other hand, a sub-department is by definition bound to a single department, then it's simply about the level of granularity that you're reporting on. A single dimension would be the preferred option then. Others may have different mileages, but that's the rule of thumb that I would use.
comma
Well, there is. But only a few (if not just one). And since it's just a few, I thought it would be simpler to create that sub department twice under two different departments, and then add another new consolidation element whose children are those two sub departments.Alan Kirk wrote:whether there is any prospect of a sub-department falling across multiple departments
Another consideration is if I created a Sub Department dimension, there's a big chance that user will match the Sub Department to a wrong Department.
What do you think?
Internet Explorer 7
Internet Explorer 7
ajain86
- Version: 9.4.1 9.5 9.5.1
- Excel Version: 2003 2007
1 dimension should be the way to go for your model. It is best when you want to avoid end user confusion. If 2 dimensions are so closely related, I find it best to combine them into 1 dimension.
The one issue I can see is that data being double counted if you have a sub department in multiple departments.
Ankur Jain
comma
I'd like to elaborate more on this dimension thing.
Let's say I have DimA, DimB, and DimC. For one element of DimA, user supposed to be able to input to only one element of DimB, and one element of DimC. In other words, one element of DimA can only be matched to one element of DimB and one element of DimC.
What's the best approach for this then? Should I create DimB and DimC as dimensions (Approach 1)? Or should I just add DimB and DimC as the attribute of dimension DimA (Approach 2)?
If Approach 1 is used, then I think it'll be less user friendly. Because after user choose the element of DimA, they still have to choose the element of DimB and DimC, when it can be automated.
But in approach 2, user cannot see the data per value of DimB or DimC, plus the selected DimB and DimC cannot be exported to Excel as a separate column.
Internet Explorer 7
Internet Explorer 7
- Steve Vincent
- Version: 10.2.2 FP1
sounds more like you need a relational database like MS Access rather than TM1. It's not the correct type of tool for entering & reporting data with those kinds of relationships.
comma
Yes, I know it's more like relational than OLAP. But can't we implement it using TM1 so we can utilize its calculation engine?
Internet Explorer 7
Internet Explorer 7
