Deleting Rule and Memory used
Goatship
Version: 9.5
Post by Goatship »
Dear all,
When I delete a rule + its feeders, then run CubeProcessFeeders (feeders-firing process), memory used become a little higher.
Intuitively it should be lower, or same if feeders re-process did not work. what happens ?
I'm new to TM1.
Re: Deleting Rule and Memory used
Memory used where?
Are you just looking in task manager or in the TM1 performance monitor }StatsByCube?
In }StatsForServer you may find that TM1's internal garbage memory has increased but remember TM1 never releases memory back to the OS.
