How can I load data into just one specific TM1 9.5.1 Contributor Workflow node using TI. In TI I don't see any options to select the workflow nodes.
Is there any other way we can achieve this without using TI. For example in Cognos Enterprise Planning tool we can dump data into IM tables using Informatica.
Thanks.
Loading data into Contributor workflow.
- sachin
- OLAP Product: Transformer,SSAS, EP, TM1
- Version: 7.3 2005 10.1 10.1.1
- Excel Version: 2013
Re: Loading data into Contributor workflow.
Have you tried loading the data in the cube (for the node in question) using TI? Did it not work?
- Sachin
- Sachin
- stephen waters
- Version: 10_2_2
- Excel Version: Excel 2010
Can you be a bit clearer about what you are trying to acheive from a functional point of view? TM1 can operate very differently from Cognos Planning (CP) and trying to reproduce what you did with CP in TM1 is not necessaily the best way.
