TI or Rule function to check if element exists in dimension
harrytm1
Version: Latest version
Excel Version: 2003 to 2019
Post by harrytm1 »
hi all,
i look through the reference guide and found TI functions to check if cube or dimension exists. however, i could not find any function to check if an element exists in a dimension and return 1 or 0.
any idea how i can achieve this check? many thanks!
Re: TI or Rule function to check if element exists in dimens
harrytm1 wrote:hi all,
Use the DimIx function. If DimIx returns 0, you can return 0 yourself from an If() function. It it doesn't, you can return 1.
harrytm1
Post by harrytm1 »
thanks Alan! it works!
