I currently need to create a group with admin right on specifiques cubes, dimension and process (a superAdmin to all Object and two admins with right on specifique object).
Is it possible?
I'm using the TM1 9.4.1 release.
Thank you for all your thoughts about that point.
New Admin Group
- rkaif
- Version: 9.1 or later
Re: New Admin Group
Create a new Group and name it MyAdmin (or anything else).
Right click on Cubes and set the Security Assignments. For the desired cubes give Admin rights to MyAdmin group.
Right click on Dimensions and set the Security Assignments.For the desired dimensions give Admin rights to MyAdmin group.
Right click on Process and set the Security Assignments.For the desired Processes give Read rights to MyAdmin group.
Hope that helps!
Hope that helps!
Cheers!
Rizwan Kaif
Rizwan Kaif
