I have reviewed the TM1 structure document, but still a little bit confusion about that.
what's difference between tm1s.cfg and tm1p.ini, and how they are working?
Thank You!
ABOUT TM1 STRUCTURE
keigo840413
- OLAP Product: COGNOS
- Version: 9.4
- Excel Version: 2003
Re: ABOUT TM1 STRUCTURE
These are both described in the Operations Guide, accessible from Help in Perspectives and Architect.
- rkaif
- Version: 9.1 or later
Tm1s.cfg file has the configuration of the TM1 Server. It is located in the data directory.
Tm1p.ini file is used to configure the Tm1 Perspective/Client environment. It is located at the following location:
C:\Documents and Settings\All Users\Application Data\Applix\TM1\Tm1p.ini
C:\Documents and Settings\<user name>\Application Data\Applix\TM1\Tm1p.iniCheers!
Rizwan Kaif
Rizwan Kaif
keigo840413
- Version: 9.4
Thank you,Got the meaning
