any news if IBM is releasing 64-bit Excel Perspective client? Now that Windows 7 64-bit is very common, and MS Office 2010 is available in 64-bit, it makes sense to leverage on the additional processing power to speed up TM1-Excel file loading and processing.
Any idea if 64-Bit Excel Perspective client is available?
harrytm1
- Version: Latest version
- Excel Version: 2003 to 2019
Martin Erlmoser
- Version: 9.1.4 FP1
Re: Any idea if 64-Bit Excel Perspective client is available
i don't thing that 64bit client-software make that much sense, but nevertheless infact that tm1 doesn't support excel 2010 it also doesn't support excel 2010 64bit (64bit is not twice as fast as 32bit..)
maybe i'm wrong, but excel2007 has no 64bit version so..
i'm sorry.
but maybe you have luck and i'm wrong.
i'm sorry.
Win 7 x64 may be getting to be quite common but not so x64 Office. Also Perspectives has a very old legacy code base which I think still includes quite a few old XL4 macros. A 64 bit version of Perspectives would probably require a major re-write probably as a COM add-in, I don't think it is something we are likely to see any time soon.harrytm1 wrote:Hi all,
- Martin Ryan
All the more reason to get it up to date!lotsaram wrote:Also Perspectives has a very old legacy code base which I think still includes quite a few old XL4 macros.
Not necessarily. Hard as it is to believe there are some things that you can't do in VBA that you still have to resort to old school Excel 4 macros for, though they're probably the more esoteric kind. Getting an accurate list of loaded workbooks (including add-ins) is one that I know off the top of my head because it's useful if you need to scan to see whether a particular add-in is loaded, regardless of how it was loaded.Martin Ryan wrote:All the more reason to get it up to date!lotsaram wrote:Also Perspectives has a very old legacy code base which I think still includes quite a few old XL4 macros.
Sub OneReasonWhyWeNeedXl4Macros()
Dim wbk As Excel.Workbook
Dim xlai As Excel.AddIn
Dim l_Xl4Count As Long, l_Xl4Idx As Long
'TM1p.xla (for example) probably won't be in this list depending on how you loaded it.
For Each wbk In Application.Workbooks
Debug.Print wbk.Name
Next
Debug.Print "----------------"
'It may be in this one, but tm1.xla won't because of the way it's loaded.
'And some .xlls may be as well.
For Each xlai In Application.AddIns
Debug.Print xlai.Name & vbTab & xlai.Installed
Next
'If you want the *accurate* list of actual workbooks that are open including .xlas,
'you need to go old school.
l_Xl4Count = Application.ExecuteExcel4Macro("Columns(Documents(3))")
For l_Xl4Idx = 1 To l_Xl4Count
Debug.Print Application.ExecuteExcel4Macro("Index(Documents(3)," & l_Xl4Idx & ")")
Next
End SubHowever I have to agree with Martin E; Harry is proceeding from a false assumption. I doubt that 64 bit client will make a blind bit of performance difference at this stage for most TM1 applications.
