hi
I have a measure and products dimension
For some products the Attr value is 1 and rest all products its 0
There is Top level in Products Dim --Total By Product
I want Total by Product to have aggregated values of products with attr value 1
(Note: For whom attr value is 1 their measure is having Values and All Other Attr measure value is zero)
How to Aggregate based on attribute value?
- vinnusea
- Version: 10.2
Vinnusea
Vinnusea
- vinnusea
- Version: 10.2
Re: How to Aggregate based on attribute value?
Think so..
Do you have any Idea how can it be DONE??????
Vinnusea
Vinnusea
['Filtered Amount']=N:IF(ATTRN('Product',!Product,FilterAttrName)=1,DB(Cube,Product, Dim2, Dim3,'Amount'),0);
Or even
Not that what @tomok wrote wouldn't work. I just feel that shorter is generally better.
['Filtered Amount'] = N: ['Amount'] * ATTRN('Product',!Product,FilterAttrName);
Or you can us a combination of TI and consolidations ...
Eg: have TI run through the dimension and if the attribute value is there then add the element to an alternate rollup. Not as dynamic as rules as it woudl require a user button click at some point but still very quick and much more efficient when it comes to memory use and calculation speed.
- vinnusea
- Version: 10.2
yes i think need to go with some TI process to make aggregate based on Attr values...
Will give it a try and update this link back
Thank you
Thank you
Vinnusea
Vinnusea
