Data source for TI Process.
Posted: Thu Nov 11, 2010 7:04 pm
by jbcraigs
We want to use TI to pull in data from DB2.
What would be a better source in terms of performance,
1. ODBC
or
2. C10 Framework Package(this would probably use DB2 client)?
Any other factors that would influence this choice besides performance?
Thanks.
Re: Data source for TI Process.
Posted: Thu Nov 11, 2010 7:14 pm
by rkaif
Use ODBC to connect to DB2
Posted: Thu Nov 11, 2010 8:22 pm
by tomok
jbcraigs wrote:We want to use TI to pull in data from DB2.
1. ODBC
or
Thanks.
if you go the ODBC route (which is the one I recommend too) the TM1 server is going to have to be able to connect to DB2 in order for it to work. This means you'll probably have to install the DB2 client on the TM1 box. I haven't worked with DB2 in a few years but that's what I had to do the last time I used it as a data source.
Posted: Fri Nov 12, 2010 6:33 am
by jbcraigs
Thanks for response. But on other forums I read that using Framework Manager package might provide better performance as compared to ODBC connection. Has anyone actually compared the performance while loading large data volumes?
Thanks again.
Posted: Fri Nov 12, 2010 8:31 am
by David Usherwood
TM1's support for FM as a data source is very new and for SAP BW at least there are postings suggesting issues. I can't see why introducing an additional layer into the mix would be faster, unless the FM route uses some kind of better eg native driver. Remember that TI is ETL ie the results are stored within TM1, so your user isn't going all the way back to DB2 for the data on their reports.
