Does anyone know if you have to change the .ini file when switching to CAM security?
I cannot seem to verify even though my account has admin access
Dan
tm1top with CAM security
dan.kelleher
- Version: 9.4
- Excel Version: 11
Neil Watson
- Version: 6 and 2.5 to 10.2.2
- Excel Version: 2007 2010
Re: tm1top with CAM security
Hi Dan,
Unfortunately this is a known bug and there is nothing that I know you can do about it. (I hope someone knows differenty), however, during the recent presentations by IBM when talking about 9.5.2 it was mentioned that this bug will be fixed, along with a change so that you will be able to see to whom the camid belongs, and not just half the camid itself.
Neil
Neil
comma
- Version: 9.5.0 64-bit
- Excel Version: 2003 SP3
There are some parameters you have to fill:dan.kelleher wrote:I cannot seem to verify even though my account has admin access
- IntegratedSecurityMode (has to be 5)
- ServerCAMURI
- ClientCAMURI
- CAMPortalVariableFile
You can see the details in the Installation Guide.
Yes, this is pissing me off too. But it would be even better if we can see the full login name instead of the CAM ID (which can't tell you instantly who are the users unless you memorize those long IDs).Neil Watson wrote:along with a change so that you will be able to see to whom the camid belongs, and not just half the camid itself
And you can see the full CAM ID from the TM1Top log as a workaround for the time being.
Windows Server 2003 Enterprise x64
Windows XP Pro 2002 SP3
Internet Explorer 7
Internet Explorer 7
- jameswebber
- OLAP Product: Cognos Express 10
- Version: CE 10.1.1
Anyone know if this has changed?
All I have found is this is fixed in 9.5.2?
https://www-304.ibm.com/support/docview ... wg1PM36166
- jameswebber
Seems like the answer from our IBM partner is no.. another Cognos Express fail
- paulsimon
- Version: PA 2.0.5
We have 9.5.1 HF 24 and we don't need any special parameters in the ini file. The parameters mentioned before are in the tm1s.cfg.
- jameswebber
But do your users show correctly in tm1top or like this:
Cmd:
Id Username State Function
5084 Th:Pseudo Idle -
3568 Th:DynamicConfIdle -
6360 CAMID("CognosEIdle -
5568 CAMID("CognosEIdle -
7052 CAMID("CognosEIdle -
3960 CAMID("CognosEIdle -
Cmd:
Lewis
- OLAP Product: Cognos Tm1
- Version: 952 FP1 [prod]
Client attribute > }TM1_DefaultDisplayValue < displays in 9.5.2 FP1 -
CAMID was still displayed in 9.5.2 base release .
- jameswebber
Yeah I read that herehttps://www-304.ibm.com/support/docview ... wg1PM36166
Not much use for Congos Express as it only has tm1 9.5.1
