we have defined our data model in TM1 Architect and then deployed it to Contributor application.
The thing is that our application also contains several TI processes. And it seems to me that these processes are inaccessible from Contributor web application.
Have I just overlooked something or is this really impossible?
Vladino
TM1 Contributor application and Turbo Integrator process
- rkaif
- Version: 9.1 or later
Re: TM1 Contributor application and Turbo Integrator process
Contributor is used for the Submit/Approve/Reject concept. If you want access to your TI Processes through the web then use TM1Web or you can also fire/execute your Process using Action buttons on your spreadsheets.
Cheers!
Rizwan Kaif
Rizwan Kaif
