tm1s.exe - load time
yyi
Post by yyi »
server boot sequence begin fast then once the commit charge reach a few hundred mbs, the rest of the cubes seem to load about 10k p/hr :( . does anyone have any tune up tips like multi thread load, mem tweaks or cube/feeder arrangements :?:
spec = win2003svr, 9.1sp3 x86, 8Gbs.
Yeon
Eric
Version: 9.4
Re: tm1s.exe - load time
Post by Eric »
What is your total load time?
Eric
yyi
Post by yyi »
total is about 12mins, what i don't understand is why the brakes go on after the first 3 seconds when it's already loaded most of the cubes in memory :?
Yeon
Eric
Version: 9.4
Post by Eric »
12 minutes is not bad. I know someone who has a load time of 6 hours! :o
potential culprit to load time after data load.
1) Feeders
2) Security
Eric
ScottW
OLAP Product: TM1 CX
Excel Version: 2003 2007
Post by ScottW »
Yeon,
If you look in the tm1server.log then you can see exactly what is taking the time.
TM1 server loads in the order:
- dimensions + element attribute cubes
- data cubes + process feeders (per cube with feeders in the rule file)
Loading data is extremely fast. The thing that takes the time is processing feeders of large cubes. It's not uncommon for the majority of server load time to be processing feeders for one or two cubes.
12 minutes is a small tm1 model by any stretch, I wouldn't be too concerned either way.
Scott W
Cubewise
www.cubewise.com
Post by David Usherwood »
You can multithread feeder loading by setting
MaximumCubeLoadThreads = <x>
in TM1S.CFG
where x should be 1 less than than the cores on your server. This works on 8.4.5 (very well) 9.1 (pretty badly) and in initial testing, 9.4 (rather well). But not on 9.0SP<anything>.
Eric
Version: 9.4
Post by Eric »
Didn't know about that, must be because I'm on 9.0 :evil:
Eric
